Al00000's avatar
Al00000
Tutor
Oct 26, 2019
MR1100 M1 Nighthark Reboots andter Firmware Update
I've had this MR1100 for a couple of weeks and it has worked well.
I run it from the USB C, so I remove the battery, as recommended. I don't know why, in 2019, the battery should be removed.
It's just invited me to upgrade to Firmware NTG9X50C_12.06.07.00.
Since upgrading, it continuously reboots while tethered for power. If I insert the battery, it is fine.
From this, I deduce that the supplied power brick is not up to the Job.
I tried to downgrade the firmware to the only one available on the support site and it said that it was the wrong firmware. Presumably this really means that you can't downgrade.
I can see from the forum that reboots are a known problem. In my case, it is clear that it is fine on battery; but not when tether-powered.
I'm about to send it back.
Any suggestions appreciated.
Is it OK to leave the battery in while on mains power?
Thanks in advance.
  • No issues with leaving the battery in.  The latest release will resolve a reset that some customers saw while running without the battery.  Also the latest release addreses charging and can now allow users to leave the battery in while plugged in.
    • LTEGuy's avatar
      LTEGuy
      Star
      the latest update will resovle the issue of running with and without the battery.  So best way to proceed would be to leave the battery in the M1 and select "Check for Updates".  Allow the update to occur and you can then continue to use the device with the battery left in the device.  Or remove it if you prefer, either will work fine.
      • Al00000's avatar
        Al00000
        Tutor
        Thanks LTEGuy.
        Can you please explain the deal with leaving the battery in, whilst on charge.
        Is it bad to do this, or does it just shorten the battery like by a little bit.
        It would be convenient just to leave it in; but it tells me to remove the power, when it is fully charged.
