BSL81's avatar
BSL81
Tutor
Oct 25, 2022
MR2100 locked to provider. how to unlock
Hi im in Aus and i have a MR2100 locked to Telstra (provider) the contract has been cancelled and i want to use it with my new provider but its locked.
how can i get it working?
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    You can contact Telstra for the unlock code. They should provide it if the device is already out of contract.
    Thanks
    • BSL81's avatar
      BSL81
      Tutor
      Turns out it doesnt need an unlock code but there is a service for unlocking as you suggested.
      an optus data sim will slot straight in and work straight away.
    • StacesPlace's avatar
      StacesPlace
      I have a Netgear Nighthawk MR1100 which I purchased through Telstra a couple of years ago. I now have an unlock code which Telstra have provided so that I can use it with another carrier. However I can not find any instructions on how to apply this unlock code. Can anyone help please.
      • W1lliam's avatar
        W1lliam
        Virtuoso
        insert different SIM card, other than Telstra, and login to Web GUI, it will be asking for unlock code
