kimsh's avatar
kimsh
MR6150 4G+5G Mode make Loop and Reboot
Hello,
I am using a Netgear MR6150.
After updating to firmware version NTGX65_12.01.74.00, the device entered a reboot loop. At first I thought the firmware update had completely broken the device, but after some testing I found the following:
If I remove the SIM card, the device boots normally.
If I enable Airplane Mode before rebooting, the device also boots normally with the SIM card inserted.
As soon as I disable Airplane Mode and the cellular connection initializes, the device immediately reboots and enters a boot loop.
I changed the network mode to 4G Only, and the device appears to work normally.
The reboot loop seems to occur only when 4G+5G mode is enabled.
Because of this, I suspect the issue is related to 5G connectivity rather than the SIM card itself.
Has anyone experienced a similar issue with firmware NTGX65_12.01.74.00?
Are there any known fixes, modem settings, carrier profile updates, or workarounds that can prevent the reboot loop while using 5G?
Any help would be greatly appreciated.
  • I experienced the same issue.
    As a workaround, I downgraded the firmware and have been using an older version without any problems.
    You may want to try firmware version 12.01.31.00. On my MR6150, that version works normally in **4G+5G mode** and does not cause the reboot loop.
  • Running the MR6150 in 4G+5G mode causing a reboot loop usually points to a firmware bug, unstable network compatibility, or signal issues. Try updating the firmware, resetting the router, testing with another SIM, or locking it to 4G or 5G separately to identify the root cause.
