BostonSailor
Sep 02, 2024Aspirant
MR6500 unstable WiFi and signal drops
I've started using this hotspot in an always-on remote application. After a week or so, the unit fails to attach new Wi-Fi devices and has very poor or no Internet access. Rebooting fixes everything, but in a remote application like this is not acceptable.
I have seen in other posts that there is a firmware update that is not available OTA from ATT. (I am an ATT user). Can you provide me with a firmware update for this unit?
- JBishAspirant
Until att releases the updates they are not available... I would suggest moving hotspot to a better signal and trying to update the firmware then...
- BostonSailorAspirantJBish, I appreciate your help. (1) If you search this community for this issue you will see many posts requesting a json config file so Netgear can provide the right update file. (2) I have the external antenna and getting excellent signal strength.
the hotspot is 24/7 powered?
Do you have the battery removed?
Have you set the wifi to high powered mode?
Tried setting it up as passthrough and connect a dedicated router to it?
