JayFray's avatar
JayFray
NETGEAR AirCard Smart Cradle (DC112A)
Hello,
Where can I buy the NETGEAR AirCard Smart Cradle (DC112A) in Europe?
Thanks.
  • I was forced to return my aircard and replace for a router from other brand because of this.
    • DarrenM's avatar
      DarrenM
      Sr. NETGEAR Moderator
      Hello trib and JayFray
      This is a EOL product but you may still be able to find them on amazon.
      DarrenM
      • DarrenM, what does "EOL" mean? :smileyfrustrated:
        I'm curious to know if this model would actually be compatible with my Verizon Wireless Jetpack AC791L, as the DC112A Smart Cradle was released a year earlier, and it was stated to be compatible with "all future Netgear Air Cards."
        Looking at the Tech Specs for the DC112A, it does not seem to support all the LTE Bands my Hotspot uses, but I just wanted to make sure.
  • I would it buy in Switzerland... or AirCard Smart Cradle (DC 113) but neither can be bought in Europe - Why Netgear is not able distributing those in Europe?  :-(
    As well as there is no response or answer from Netgear and their Support.  :-(
  • eBay?  I just bought one that was used with an MEA carrier.  It is working fine out of the box with my US AirCard 781S.
    Netgear support in the US said they were NLA this spring.
  • I just hooked my to a AC791L to a DC112a(Zain) and it works until a power cycle then the AC791L get stuck at the USB charge/teather question and wont start up till you answer the question on the AC791 after you answer the question it works well. I wih I had a reguler model rather than the Zain one because firmware updates will be never happen.
