MidnightMerc
Sep 27, 2024Aspirant
Netgear Night Hawk MR5200 No Service
I have the MR5200-100NAS and it cannot get a signal with any carrier. I had tried Verizon, TMobile, and ATT SIMs and all three are not working in my device. I have also verified that the SIMs work in another MR5200. TMobile believes the device is locked and want to charge me a fee to unlock it. I'm sure I had purchased the device unlocked though.
I found this discussion and did try a factory reset.
Re: Netgear Night Hawk MR5200 cant find service. - NETGEAR Communities
The device still does not get a signal. I would like to update the firmware to see if that helps . The firmware version is NTGX55_12.04.17.00, firmware build date 2023/03/01. How do I get the firmware? I cannot find it listed on Netgear's support site.
Thanks.
- MidnightMercAspirant
Bumping this post
Seeing if anyone has an idea or anywhere they can point me to on troubleshooting this. I tried to search around and couldn't find anything helpful
- rcpaxLuminary
does it give you an error? check on both the LCD and web and see what message you get after it boots up and try to acquire a signal.
If it's truly locked, upgrading the firmware will not do anything to it. i think you need to ask the seller about this. a truly unlocked device should boot up and acquire a signal on any sim. also see if the correct apn is set, to match the sim you're using.- MidnightMercAspirant
Thanks for responding!
On the screen, there are two prompts:
First
APN Setup Required
To connect to the Internet, please setup your APN.
Second
Mobile Broadband Disconnect
Your data connection is disconnect
The admin page show a prompt as soon as I login:
APN Setup Required
Please select an APN or click on submit button to create a new APN
There is a drop list with two options:
vzwinternet
vsblinternet
I tried both and it just shows Searching. The same SIM in another MR5200 (that works fine) APN shows vzwinternet
The signal strength shows Excellent and has a Service Number.
The device was purchase through Netgear directly and not a shop so I believe the device is unlocked.
Not sure what else to do here. Any suggestions is appreciated.
- rcpaxLuminary
Try the suggestions on this post: https://community.netgear.com/t5/Cell-Service-Mobile-Hotspot/How-To-Use-a-VERIZON-Nano-Sim-with-the-NETGEAR-MR5200-Mobile/m-p/2217693
This sounds like a persistent problem with Verizon.
