nhantenna's avatar
nhantenna
Apprentice
Jan 22, 2019
Nighthawk M1 + 2 external antennas
I have a Nighthawk M1 with 1 external antenna.  Anyone out there have 2 external antennas?  If yes, can you share speedtest results between 1 and 2 external antennas?  Is it double?  About the same?
  • Ive done this.
    Standard NH : 35/12
    One antenna (patch): 50/18
    Twin Yagi's : 120/35
    Best of luck,
    • nhantenna's avatar
      nhantenna
      Apprentice
      thanks adzza
      a primary way to get speed out of this Netgear 5G evolution hotspot is multiple CA.  When I see your speeds double when you add the second external antenna i suspect this is 2 CA.  That said, if CA is NOT supported by your local cell tower, i would not expect adding a second antenna to do much speed-wise.  anyone else have thoughts on this?
        nhantenna
        Apprentice
        adzza i noticed you state "One antenna (patch)".  ie not yagi.
        another data point that would be interesting would be one yagi.
  • If you have to use external antennas then it is wise to use two. Technically that is not as simple. It depends on on how many bands you have available and how many streams. With 2x2 Mimo it means that one band has two streams. Depending on current air radio condition each stream has CQI which affect stream modulation which directly affects speed. If you have only one band, two streams, both streams are not  necessarily in the same modulation.
     If you do experiment with one antenna or two, please make sure you have same carrier aggregation combo active when you compare results.
      nhantenna
      Apprentice
      TeeJay74 "please make sure you have same carrier aggregation combo active when you compare results"
      can we see the CA details on the nighthawk lcd panel?  nighthawk web page?  other?
      • TeeJay74's avatar
        TeeJay74
        Virtuoso
        No, not able to see that on LCD  or webgui. Need to use AT!GSTATUS? command output.
      nhantenna
      Apprentice
      TeeJay74 I live in a rural location.  Cell tower to the north.  Cell tower to the south.  For maximum speed performance do the two external antennas have to be pointed toward the same cell tower?  Or can I point one north and one south?
