Christian1981
Jan 30, 2019Tutor
Nighthawk M1 / MR1100 Firmware Update (12.05.05) Failure
I tried to update the Firmware from my Nighthawk M1 Router from 12.04.02.00 to 12.05.05.00 and it failed.
I did the following:
- Downloaded the Firmware 12.05.05 from Netgear's official support page (https://www.netgear.com/support/product/MR1100.aspx).
- Upload firmware package via web interface (http://m1login.net)
Upload failed (Errorcode 13; no further explanation)
I also tried:
- Netgear App is not working with current version of Firmware ("not able to connect to Router")
- Firmware 12.05.05 is not detected through "autoupdate function"
Has anybody an idea how I can update the Firmware?
I'm guessing the update is not for the EUS versions.
When updating the router says the update is not intended for this device.
I went on the dutch website and there is an update "MR1100-100EUS_23113509_NTG9x50C_12.06.03.00_00_Generic_05.01.secc" and this one works.
You may wanna change the country of the support site (bottom of the page) your country or a logical country nearby (Belgium>>> Netherlands).
And indeed, the update from within the router doesnt work.
- Blanca_ONETGEAR Employee Retired
Welcome to NETGEAR Community!
May I please know the exact model of your MR1100? Where did you purchase it?
Kindly try to log into the M1 Web UI using http://m.home/ and update the firmware.
Blanca
Community TeamHi Blanca_O ,
Web UI is not working with http://m.home/
I need to use http://m1login.net and I already tried to update from there. Result: No Update found.
Exact Model is MR1100-100EUS_04.01.67.00
Best,
Christian
- ErwinCrAspirant
