Stephen1234's avatar
Stephen1234
Initiate
Dec 06, 2018
Nighthawk M1 data usage not displayed
After the most recent software upgrade, my M1 stopped displaying data usage. I took it into a Telstra shop, and they did a factory reset. Now it displays "Detecting service". It still connects to the Internet, but the lack of data usage display is annoying.
  • Fshow , thank you for the update and glad to know that it is now working.
    Hi Blanco,
    Went back to Telstra first with what i found reccommended elsewhere in the forum.
    Kindly get in touch with Telstra and have them double check to ensure that it reached the billing server..
    Back online now and sorted, thanks for following up with me.
    Thanks
    FShow
