BrianP82's avatar
BrianP82
Nighthawk M1 monthly cycles starts
Monthly cycles starts is grayed out.
Days left is stuck at 0.
Can't change.
I have done 3 rests and firmware is up to date.
It is a AT&T version unlock and using Visible Sim.
Any help would be nice.
Also can I flash Netgears firmware or am stuck with AT&T firmware.
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi BrianP82
    Welcome to NETGEAR Community!
    Does it display the same status on the MR1100 LCD?
    How did you reset the device? Please remove the SIM card and hold down the reset button until you see a change in the LED.
    Blanca
    Community Team
    • BrianP82's avatar
      BrianP82
      I did reset again without sim and used button in the back.
      No charge. LCD shows data used and resets when power off the device.
      • Blanca_O's avatar
        Blanca_O
        Hi BrianP82
        Can you still go online even though it shows 0 Day/s remaining?
        Blanca
        Community Team
