AndyR71
Feb 23, 2018Tutor
Nighthawk M1 MR1100 external antenna setup
I've just connected a Panorama 3G 4G 4GX MiMo Antenna to my Nighthawk M1 MR1100 and just wondering if I need to go into the settings and tell it to use (look for) the external antenna now? I had a look around and can't seem to find it anywhere and the signal strength hasn't really improved.
Thanks.
- KarmusDKApprentice
Remember to plug it into a wall adapter as soon as you connect external antennas. It uses a lot of power and will drain the battery completely in a few hours of heavy usage.
Do you connect the Nighthawk M1 MR1100 antenna directly to the M1 hotspot?
- JasonNNETGEAR Employee Retired
Hi Richard_J,
Please refer to the link below and let me know if that helps fix your issue. :]
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/Nighthawk-m1-Antennas/td-p/1495222
- Jason N
