Darcko's avatar
Darcko
Nighthawk m1 no connection
I have a nighthawk m1 router, i can't connect to it.
The wifi doesn't show up on any device (laptop, phone)
Ethernet to the laptop does not work ( network cable unplugged)
USB connection also doesn't work (network cable unplugged) even though it shows on my devices.
On the device it self it keeps telling me that the apn needs configuration and the broadband connection is not available even though it is.
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi Darcko
    Welcome to NETGEAR Community!
    Kindly do a factory reset using the Reset button. Press and hold the Reset button for five seconds. The mobile router returns to factory settings.
    Was this working before?
    If so, what happen prior the issue occur?
    Blanca
    Community Team
    • Darcko's avatar
      Darcko
      Thanks for your reply.
      The last thing i did was using the router with a different sim card (meaning another carrier) and it was connected, but one day it just wouldn't accept any sim card.
      Yes i did a reset oh so many times.... After factory reset it just stayes the same with my original post..
      I believe there is problem with framware but i can't connect to it to download a new patch
