naro's avatar
naro
Follower
Aug 04, 2021
Nighthawk M2 - Firmware Update Stuck
Hi,
I've currently on firmware: NTGX24_10.17.08.00 with modem SDX24_10.25.00.06.
Whenever I try to update the firmware via the physical device's GUI or via the webapp, it just hangs forever.  There appears to be no way of manually uploading firmware and I can't see if I'm on the latest firmware version.
Can you help?
Thanks.
  • I have the same problem. Sweden. Telia is the carrier. Any solutions? Is there somewhere we can download a new or old firmware to manually upload?
    • StephenB's avatar
      This is  a 5 year old discussion thread.  Best to create your own discussion thread.
      In general, distribution of Netgear's  mobile router firmware is often managed by the carrier.  No idea if that is the case with yours, but maybe also try contacting them.
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    naro wrote:
    Hi,
    Can you help?
    Thanks.
    Just checked. Your device is already on the latest release.
    Thanks
    John
    • Jake74's avatar
      Jake74
      If my modem is already on the latest firmware release, why can't I connect to the EE mobile network in the UK?
      My EE sim card has perfect reception when in my mobile phone but it won't connect when it is in the MR2100 router?
      thanks
      • JohnPeng's avatar
        JohnPeng
        NETGEAR Expert
        thanks
        UNfortunately, EE MR2100 is a carrier SKU. We can't push out the new update without EE approval.
        Thanks
        John
  • 1. the router continually drops connection to EE mobile network. It worked when I first purchased it but now it hardly ever connects.
    2. There are no firmwear updates in the download centre?
    3. I am about to throw my Nighthawk in the trash and buy a Huawei.
    I will appreciate any help or guidance I can get.
    Thank you in advance.
