Aggie83
Dec 06, 2018Aspirant
Nighthawk Mobile stops working
Howdy.
I just replace my old hotspot with a Nighthawk MR1100 and am having an odd problem. The mobile router will suddenly stop allowing the internet connection to devices. The router still shows a LTE connection, and phones' data still works on LTE connection (not through the router), but it does not work. The router shows that the 9 devices are connected, and the devices show they are connected, but no joy.
I am hoping this is a setting which can be corrected! I found that if I turn off the mobile router, wait a few minutes and restart it, I 'may' get internet connection on my devices. I completely reset the mobile modem as well. Again, in my WinX laptop, ti shows connected and does not indicate the 'lost internet' asterisk in the toolbar.
Any thoughts appreciated.
- Aggie83Aspirant
I am in the US and have the ATT MR 1100 router. Sorry for confusion.
- Mexoh1To7kApprentice
Can you still access the M1 (like the web interface) from the devices at the moment the connection drops?
I would also check the ip addresses and the routes when the disconnection happens.
- Aggie83Aspirant
I will try that tomorrow. The ATT cell tower is our only communication, so if I swap out the sim card to the Nighthawk, I will not have internet.
Also, which IP addresses to I need to check? On my laptop?
Thank you very much. We have owned this for three days. It worked perfectly the first day. On day two, it would only work for a few minutes at a time, but my iPhone still was getting data.
Karen
The default IP address of the NightHawk is 192.168.1.1.
You can access the web interface via http://192.168.1.1
