reading_na's avatar
reading_na
Follower
Mar 07, 2023
Nighthawk MR1100-1TLAUS Firmware Upgrade
Good afternoon ,
I just did a factory reset on my Nighthawk MR1100-1TLAUS.
I am trying to upgrade the firmware to the lastest version
( MR1100-1TLAUS_23113199_NTG9x50C_12.06.02.00_00_TELSTRA_04.04.secc.spk )
I use the check for upgrades it doesn't return any updates and I have also down loaded the above mentioned file and it also fails the manual update process with an error ( Invalid Update File: Error Code 16 )
Would any one be able to point me in the right direction to solve this issue.
Thanks in advance.
Nigel
  • Hi everyone,
    I recently got a Netgear Nighthawk M1 (Model: MR1100-1TLAUS - Telstra) from a friend. I am looking for a solution to manually update the firmware, as the OTA function is not picking up the latest version.
    Device Details:
    Current Firmware: NTG9X50C_10.25.01.00
    Netgear Initial Firmware: NTG9X50C_10.25.01.01
    Target Firmware: I want to upgrade to the latest version NTG9x50C_12.06.08.00.
    The Issue: Since I cannot update via the WebUI
    My Question: Has anyone successfully updated a Telstra unit from version 10.25.01.00 directly to 12.06.08.00? I have tried manually updated via WebUI but it showed error 16
    Any guidance on the correct procedure to force this update would be greatly appreciated.
    Thanks!
    • StephenB's avatar
      Device Details:
      I see a link in this post you could try:
      • https://community.netgear.com/discussions/aircard/mr1100-nighthawk-m1-manual-firmware-update---telstra/1949065/replies/1951659
      http://www.downloads.netgear.com/files/GDC/MR1100-1TLAUS/MR1100-1TLAUS_23113199_NTG9x50C_12.06.02.00_00_TELSTRA_04.04.secc.spk
      A bit older than you are looking for.  But Netgear normally doesn't provide links for carrier-specific products.  You could try reaching out to Telstra.
  • Hi
    I have exactly the same problem with firmware upgrades on my MR1100-1TLAUS. MR1100-1TLAUS_04.01.73.00
    build 9TG9X50C_12.06.02.00
    The check for updates fails to retrieve any later revisions of the firmware.
    When I try and manually install Firmware MR1100-1TLAUS_23113199_NTG9x50C_10.25.01.01_00_TELSTRA_03.22.secc I get the message Invalid update file error code 16.
    I Also tried Version 12.06.05.00 where I receive a message - invalid update file. this update is not intended for this product. (MR1100-100NAS_23113828_NTG9x50C_12.05.05.00_00_GenericNA_01.02.secc)
    The same with  Firmware Version 12.06.11.00 (MR1100-100EUS_23113509_NTG9x50C_12.06.11.00_00_Generic_10.03.secc)
    Has anyone resolved this issue. I am sure there are important security patches in the later firmware versions
    Thanks
    Peter
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    Please check the FW version on your device. Your device may be on the latest release already.
    Latest release:
    FW:12.06.08.00; PRI 05.05.
    Thanks
    • Laoskido's avatar
      Laoskido
      Is there a miss listed source for this Mr1100 1tlaus version on the netgear GPL release ?
      Currently, there are 2 files, one for pri 04.04 and other for 05.05
      However, both are identical , point to 1 file of downloaded.
      Furthermore, the releases on GPL is 12.06.02.00, this is way different than what stated for pri 05.05
      Could you please check sir
