Deparnieux's avatar
Deparnieux
Nighthawk MR1100
Went to get on the computer, no WiFi. Turned on the hotspot to see what is the problem, and it says
“Updating device, please do not power off”
The little progress bar has made no progress in hours. I’ve tried removing the battery, using the reset button, and holding the power button to no avail. Any suggestions?
  • If you remove the power (AC and battery) and SIM, then power back up without the SIM installed.  Does it boot up and say "SIM not ready" or something similar?  If so, power down, reinstall SIM and boot back up.
    Does it come up to the main screen OR go right into "Updating?"  If Updating, leave in battery and connect to AC for 10min.  If it is really updating the firmware you should see the unit reboot and the screen flash a few times over the course of 5min or so.  If no progress, try holding in manual reset button for 10sec or so until message is displayed. and then repeat the above.
    If this doesn't work, its likely the firmware is corrupted and service will be required.
  • JasonN's avatar
    JasonN
    NETGEAR Employee Retired
    Hi Deparnieux,
    I wanted to check in with you and see if the steps JSnee21 have provided helped fix your issue.
    Please let us know. :]
    - Jason N
  • I tried the steps, but sadly they didn’t work. I had to take it in to be replaced. Thanks for the help!
    • JasonN's avatar
      JasonN
      Hi Deparnieux,
      Thank you for responding. :]
      I'm glad you have found a work around.
      - Jason N
