Vispen74
Jul 03, 2017Tutor
Port Forward problems DC112A
No matter what port I forward in the settings, I will always be forward to some Netgear AirCard error page when trying to reach my server from outside.
I connect to internet with a AirCard AC785 that is docked to DC112A. I have made the port forwarding in the Cradles settings.
Please help, how to do to get the port forwarding work?
- DarrenMSr. NETGEAR Moderator
Have you setup the port forwarding on the Aircard interface as well as the dock itself?
DarrenM
- Vispen74Tutor
No, only in the dock. Do I need to set the port forwarding in the aircard as well? Should I point to the usb adress (.4) or the end equipments lan adress when forwarding ports in the aircard?
As a temporarily solution I set the Aircard in bridged mode to make it work.
Hello Vispen74
That could be the issue was both the dock and air card routing was causing a conflict so you will have to bridge one or set the dock as a AP.
DarrenM
