stopper9327's avatar
Feb 03, 2021
red light
Hi All
Help needed my Mr2100, as a red flashing light showing no wifi signal so can't connect.
Sid is ticked but not broadcasting the wifi, works via ethernet, light flashes blue but when unplugged goes back to
red, no wifi signal being broadcast x near the wife emoji. any help please. thanks
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi stopper9327
    Welcome to NETGEAR Community!
    Please check if Wi-Fi Standby option is set to Disabled
    May we please know the device SKU (e.g. MR2100-100NAS)? This can be checked on the box of the product or on the barcode label
    What is the firmware version?
    Blanca
    Community Team
    • stopper9327's avatar
      stopper9327
      Guide
      Hi Blanca
      Thanks for replying, I can confirmed that the wifi stanby is set to disabled, mt sku is : SKU:MR2100-1EEEUS, I have a EE data sim
       for the device which was working perfectly until now. The firmware is NTGX24_10.13.09.00 do you think my firmware could be corrupted?
      regards
      stopper9327
      • Blanca_O's avatar
        Blanca_O
        Hi stopper9327
        Were you able to check if there is a new firmware update available?
        Kindly do a factory reset using the Reset button. Press and hold the Reset button for five seconds. The mobile router returns to factory settings.
        Blanca
        Community Team
    • Blanca_O's avatar
      Blanca_O
      Hi Matty_K85
      Please provide the device SKU (e.g. MR2100-1EEEUS) and firmware version.
      Blanca
      Community Team
      • Matty_K85's avatar
        Matty_K85
        Tutor
        Hi Blanca,
        Thank you, here are the requested details:
        SKU: MR2100-1TLAUS
        Firmware: NTGX24_10.17.10.00
        Cheers,
        Matt
