Flue
Sep 27, 2017Aspirant
slow wifi (.4 mbs ) ok when tethered nighthawk m1100
Thankyou for your assistance.
A simple factory reset and renewing settings solved my wifi speed problem.
- DarrenMSr. NETGEAR Moderator
Hello Flue
Can you give some more detail on the issues you are having.
DarrenM
- FlueAspirant
Thank you for your interest
simple problem.
when connected via wifi i test speed of Ping 430 ms download 0.4mbs.upload 0.8 mbs. testing to melbourne telstra.
when connected via tether i get Ping 25 ms download 64.6 mbs upload 48 mbs,
this suggests that wifi is not working correctly.
Does anyone have a solution?
- FlueAspirant
