Todd6941's avatar
Todd6941
Follower
Mar 14, 2019
Verizon AC791L Jetpack
I have a AC791L Jetpack from Verizon and there is an “Alert” that will not clear. I log into the admin site and the alert states that the SMS memory is full. I go to check my messages and there ore “no” messages to view or delete. So I press delete any ways and the Alert is still there. I “factory reset” the AC791L and the alert still remains. I am at a loss and going nuts. I really want the know what the alert is and I want it gone. If anyone has any insight on this issue I appreciate to hear it.
  • Hi Todd6941
    Welcome to NETGEAR Community!
    Factory reset should clear all memory on the AC791L Jetpack. We suggest that you call Verizon to check if they have something saved for your line on their end. Can you also check if there is a firmware update available?
    Blanca
    Community Team
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi Todd6941
    Blanca
    Community Team
    • Blanca_O's avatar
      Blanca_O
      Hi Todd6941
      We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
      Blanca
      Community Team
    • souixbee's avatar
      souixbee
      I had the same issue. Verizon tech support didn't have a clue. The problem appeared when I did a factory reset to get the date corrected. I tried a second reset just in case that was the issue. Still nothing. How do I check for firm ware?
