Electrical
Aug 07, 2019Tutor
100Mbps throughput on 1Gbps fiber connection
I'm running a throughput test with iperf between an M6100 with 2 physical fiber connections in a LAG configuration that run to a M4100 in a nearby building. I've checked the settings on both devices ...
- Aug 08, 2019
Alright, so there's something wrong with the 1Gbps NIC in one of the laptops. We hooked up a new USB-C NIC and are getting the advertised speeds. Thanks for the replies.
schumaku
Aug 07, 2019Guru - Experienced User
Would be interesting to see the SFP+ ports and related LAG config fragments.
Consider to get in touch with the Netgear support anyway...
- ElectricalAug 07, 2019Tutor
M6100 Config
LLDP Remote Device Summary Local Interface RemID Chassis ID Port ID System Name --------- ------- -------------------- ------------------ ------------------ 1/0/25 155 CC:40:D0:37:80:A8 0/24 2/0/25 154 CC:40:D0:37:80:A8 0/23 interface lag 25 cos-queue min-bandwidth 0 2 0 0 0 0 0 description 'Building 25' vlan participation include 501-505,1030 vlan tagging 1,501-505,1030 Media STP Physical Physical Link Loop Partner Flow Intf Type Mode Mode Status Status Status Control ------ ----------- ------ ---------- ---------- -------- -------- ------------ 1/0/25 1000LX DIS Auto 1000 Full Up On 2/0/25 1000LX DIS Auto 1000 Full Up On lag 25 FWD Up NA
M4100 Config
LLDP Remote Device Summary Local Interface RemID Chassis ID Port ID System Name ------- ------- -------------------- ------------------ ------------------ 0/23 1 A0:63:91:82:26:98 2/0/25 NetGear M6100 0/24 2 A0:63:91:82:26:98 1/0/25 NetGear M6100 interface lag 1 description 'Uplink to CORE' ip dhcp snooping trust ip dhcp snooping log-invalid vlan participation include 501-502,504-505,1030 vlan tagging 1,501-502,504-505,1030 exit Media STP Physical Physical Link Loop Partner Flow Intf Type Mode Mode Status Status Status Control ------ ----------- ------ ---------- ---------- -------- -------- ------------ 0/7 1000TX FWD Auto 1000 Full Up On 0/8 1000TX FWD Auto 1000 Full Up On 0/9 1000TX FWD Auto 1000 Full Up On 0/10 1000TX FWD Auto 1000 Full Up On 0/23 1000BASE-LX DIS Auto 1000 Full Up Off 0/24 1000BASE-LX DIS Auto 1000 Full Up Off lag 1 FWD Up Off- ElectricalAug 07, 2019Tutor
I removed cos-queue min-bandwidth from the global config. Will test again and report back.
- ElectricalAug 08, 2019Tutor
