DigitalVT
Nov 07, 2020Guide
12v fan on 5v supply?
Just received my pair of Noctua NF-A4x20 FLX fans I intended on replacing the stock ones to reduce the noise of the refurbished switch I've just bought, which I waited until I received it to check th...
schumaku
Jan 18, 2021Guru - Experienced User
Can't see anything strange - except of that people try to put in replacement fans able to create a light airflow (40% less than the 5000 min^-1 Delta fan variant, max rotation speed 5000 vs. 13000 making less than 25% of the max airflow, and some 85 of the max air pressure). How easy it is to build a "silent" fan at these limitations (lower fan tip speed - this is whee most aerodynamic noise is coming from). In my opinion a fan not fit for replacing in any of these switches, even if it rotates, and the Fan error LED does not go on.
If an amateur aircraft builder would ask me if this engine and propeller combination ("hey I found a sooo silent solution and my Piper L-4 with it's Conti A-65 flies great") would fit his next project designed for a much bigger engine and better prop, he will hear that the takeoff run over 50 ft obstacle will be much longer, the max rate of climb will be nuts, and last but not least the cruise speed will be poor. Overall, doing so would be a major safety risk, and I'm most likely unable to sign-off his project powerplant.
The FFB0412SHN nominal 12 V models have a rated operating voltage range from 4.5 to 13.8 V as per the specs - so 5 or 6 V voltage is OK. As DigitalVT mentioned, this lower "cold switch" fan voltage is certainly implemented this way to allow lower minimum rotation speed - and it will come up to higher voltage if required. Depending on the Noctua fan motor design, it's well possible that the fan does rotate easier in the non-intended rotation direction. For example small classic DC brush engines (think of what Mabuchi builds in zig millions of and millions of one model every year) are timed to rotate in one direction for ideal power output including the torque. To let them rotate backwards, a much lower voltage is sufficient, but power out and efficiency will be ways below. And yes, several Mabuchi can be ordered from the factory for alternate rotation direction, and many can be re-timed by bringing the brushes for it. Enough said on this excursion here.
Note: There is absolutely nothing wrong with the Noctua fan design and specifically the NF-A4x20 (FLX just designates the add-on electronics for interfering even more) - if is deployed where the massive lower cooling capacity of the airflow is acceptable - they just can't replace any FFB0412 variant.
DigitalVT
Jan 18, 2021Guide
Am sure the stock Netgear fan is great for switches in an enterprise scenario where the switch is under full load, speaking for myself, just want a switch with enough ports that can accomodate various connectivity around the home without additional switches elsewhere or having to manually repatch, thus the device itself wouldnt be under much load, therefore a slight breeze from these quieter fans may be enough to keep the Netgears internals cool enough to be accpetably quiet in a home environment?
I've got 8x PoE cameras, 3x PoE AP's, a PoE Cloudkey and multiple wired ethernet devices. My thoughts that a Noctua or other "quiet fan" running at 100% capacity keeping the internals cool when the switch is not busy and then may take longer to cool for the "short" busy times, is an acceptable useage, giving a quieter environment?
- DigitalVTMar 06, 2021Guide
Hello pn23,
sadly still waiting for delivery. It's been two months tomorrow since I ordered it, the tracking mentions it arrived in destination country on 15th Feb and on the 22nd Feb it was accepted by the last mile courier. Have received two items I've ordered weeks after, and many other items have also followed in the black hole/depot these fans are sitting in.
Maybe this week? But have been hoping that for a number of weeks!
- DigitalVTMar 09, 2021Guide
The fans arrived today!! pn23, your post must have got their attention!!
Received 7 fans, 3 pairs and an odd one. Guess I didnt get 4 pairs when ordered!!
This version of GS752TP has the fan connectors underneath a board, so not as easy to swop fans over.
I've tried all 3x of the new pairs and not one fired up. When I tried the fat SunAce40 (theyre almost 30mm deep), a little smoke came from somewhere, so pulled the power quickly.
Don't understand why Netgear fans are wired differently to ALL Other fans. I presume I need to change the polarity. But why? Netgear, WHY? Guess I've gone through a pair of Noctua, some others and now these!
Can someone just clarify the pin conguration, polarity for me please?
The Netgear stock fans, looking from top, left to right are - Red - Blue - Black
The others i have are - Black - Red - Yellow.
Your help would be apprecaited. Many thanks.
- pn23Mar 09, 2021Aspirant
Hi DigitalVT
I am using a GSM7248Pv1h1. The stock Delta fans that are in it are red (+), black (-) and blue (sense/tacho)
I have tried a few different manufacturers of coolers that match the spec for voltage, current, power, starting voltage etc and they all do the same thing - spin up for a second then stop.
Sunon and others use yellow wires for the sense pin, and the red and black remain the same as you'd expect. When trying Noctua fans, I'm pretty sure I had to reverse the +/- pins as they were the other way around on the switch, but it's been a while since I did that so I could be wrong!
I have also tried different fans in a GSM7248. That device has 3 fans. Trying new fans on the headers for 1 & 2 did the same thing, spin for a second then stop, but when I tried a new fan on the header for 3 it worked. The stock fan connected to 3 was 20mm deep, the ones connected to 1 & 2 were 15mm deep, but the fan on 3 was the noisest. Whether stock or not, it seems to run at full tilt from power on, and having the sense pin connected or not made no difference at all. It is deafening.
Some of the stock fans may have onboard controllers or dependant hardware that the switch may be looking for and if it doesn't see them, cut the power I guess.
I'm going to keep trying when I have time, but may eventually have to call it a day and get rid of them and drop in some silent HP equipment instead. Shame really as I have mountains of Netgear kit and would prefer to stick with one vendor.
