DigitalVT
Nov 07, 2020Guide
12v fan on 5v supply?
Just received my pair of Noctua NF-A4x20 FLX fans I intended on replacing the stock ones to reduce the noise of the refurbished switch I've just bought, which I waited until I received it to check th...
DigitalVT
Mar 11, 2021Guide
Well, these are the ones that worked. They do spec 40db per fan.
https://www.aliexpress.com/item/32381567224.html?spm=a2g0s.9042311.0.0.27424c4dkENqYg
I've just updated the firmware and now not a peep out of the network ports. :smileymad:
Am going to give it a rest for a few days...
pn23
May 18, 2021Aspirant
Hey DigitalVT did you manage to get any further with this and were you able to resurrect your switch?
- DigitalVTMay 19, 2021Guide
Hi pn23,
Yeah, the fans installed okay. My switch issue was that when I did the firmware update, I guess either it performed a factory reset or I did and came back on the default IP address (192.168.0.239), which is not in my subnet (172.16.0.x). So couldnt see it.
So it is back and working, but noisey, still, even louder in the rack case!! So back to square one.
Was considering the new line of Netgear switches, but don't have any cash to spend at the moment!
pn23, did you progress purchasing a replacement fan yet?
- pn23May 20, 2021Aspirant
Yeah, other than the Noctuas, I have tried Sunon HA40201V4-1000U-G99 (3 wire with RPM/tacho feedback) and Sunon MF40201V3-1000U-F99 (3 wire with locked rotor detection) and had no luck. Same behaviour as all of the others, they spin up for a second then stop.
I'm completely stumped.
