DigitalVT
Nov 07, 2020Guide
12v fan on 5v supply?
Just received my pair of Noctua NF-A4x20 FLX fans I intended on replacing the stock ones to reduce the noise of the refurbished switch I've just bought, which I waited until I received it to check th...
DigitalVT
Jul 01, 2021Guide
It's been a while since I tried them, but they didn't work with various configurations. Unless you've tried otherwise? Thanks.
tmittelstaedt
Jul 27, 2021Star
Ya know, ya'all could have solved this by just leaving the case of the switch open and buying a plain old 120v desk fan with a large diameter blade, and setting it to turn slowly and point at the switch circuit board.
it sounds to me like none of you either read or understood the earlier post that made the connection between airflow, rpm and noise.
