mpitech
Feb 18, 2019Aspirant
2 stacks lag
I need to link a 4-switches stack of S3300 to a 2-switches stack of M4300. What would be the best practices here ? Specifically, is setup a 8-ports LAG (linking each S3300 to the 2 M4300) a good idea ? I have the available ports, so I don't care if it's a bit overkill, I really want redundancy here as the M4300s are connecting our filers and our vmware hypervisors. I wonder about the performance of such a setup, though.
Hi mpitech,
Welcome to our community! :)
It seems that you wanted to link these 2 stacks of switches. That's really a good idea on connecting it with 8-ports LAG as long as it is properly configured. I don't think that it is possible to stack both S3300 with M4300 as it is not on the same family version.
- JohnC_VNETGEAR Employee Retired
Hi mpitech,
- mpitechAspirant
OK thanks.
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
