navyguy
Dec 22, 2017Aspirant
24 port managed ethernet switch
I am looking for a managed 24 Gigabit Ethernet port multilayer switch that works on layer 2 and layer 3. The switch must have redundant power supplies. Also it must be 19” rack mounted taking up 1U o...
navyguy
Feb 22, 2018Aspirant
Does anyone know the power consumption for the models listed?
schumaku
Feb 23, 2018Guru - Experienced User
navyguywrote:Does anyone know the power consumption for the models listed?
You can derive the max continuous power requirements directly from the heat dissipation numbers.
navyguy wrote:Does anyone know the lower bound for relative humidity for the Netgear ProSafe M5300 switch series? The upper bound is listed but not the upper bound.
The lower bound is unspecified because there is no requirement for any humidity for the switch operations - so take it as 0%.
I hope you can get this confirmed officially from Netgear - I'm not keen to get imprisoned for "providing false information" when travelling abroad. However, have done several military projects including maritime military installations, some inherited special packing of IT industry standard systems for naval similar mil 19" installations. Good luck for yours!
- LaurentMaFeb 23, 2018NETGEAR Expert
Thank you, schumaku this is correct.
navyguy I would consider M4300 series instead, which has replaced M5300 series. Max power consumption in Watts is listed for every model in the M4300 datasheet (search page 49). As DaneA mentioned, I would be cautious with MIL-S-901D Grade B or Cisco IOS compliance requirements. If these requirements are mandatory, then you shouldn't consider NETGEAR M4300 series.
- navyguyFeb 23, 2018Aspirant
What shock and vibe standards does the M4300 switch series meet?
What is a ballpark estimate on the EOL for the M4300 switch series? We are replacing our current switch because it has reached its EOL. So we don't want to replace this switch with a new one that has a EOL within 3 years.
Does the M4300 ethernet switch series have stacking capablity of stacking switches that are more than 3 meters apart?
