navyguy
Dec 22, 2017Aspirant
24 port managed ethernet switch
I am looking for a managed 24 Gigabit Ethernet port multilayer switch that works on layer 2 and layer 3. The switch must have redundant power supplies. Also it must be 19” rack mounted taking up 1U o...
LaurentMa
Feb 23, 2018NETGEAR Expert
Thank you, schumaku this is correct.
navyguy I would consider M4300 series instead, which has replaced M5300 series. Max power consumption in Watts is listed for every model in the M4300 datasheet (search page 49). As DaneA mentioned, I would be cautious with MIL-S-901D Grade B or Cisco IOS compliance requirements. If these requirements are mandatory, then you shouldn't consider NETGEAR M4300 series.
navyguy
Feb 23, 2018Aspirant
Does the M4300 ethernet switch series have stacking capablity of stacking switches that are more than 3 meters apart?
