netgipg
Feb 04, 2014Novice
7328sv2 firmware, changes 8 to 10?
Hi, Looking for the latest downloads for a GSM7328Sv2 I see 8.0.3.34 and also 10.0.0.31. 2 version numbers is quite a jump. I have 8.0.3.25, do I go up in 8 or on to 10? Thanks
Jedi_Exile
Feb 05, 2014NETGEAR Expert
netgipg wrote: There is no documentation for v10 available at all that I can find. Please correct/direct me.
A short script that I used before now gives me an error "An invalid interface range has been used for this function. An interface range must be 1000 characters or less." as soon as I type "interface range "
Looks like I'll be booting back in to v8 tonight.
You the v10 CLI guide from following link:
http://www.downloads.netgear.com/files/GDC/M5300/M5300%20CLI%2027Nov2012.pdf
As for the range, modify your script since the new firmware 10.0.0.x follow M5300 CLI changes
instead of
interface range 1/0/1-1/0/20
Now you can do
interface 1/0/1-1/0/20,1/0/24,1/0/28-1/0/30
I hope that helps.
