Elad6L
Jul 21, 2021Aspirant
802.1AS support in M4300
Hello, Does the M4300 series (and specifically M4300-24x) support or plan to support the gPTP clock sync protocol defined in 802.1AS? I have found no documentation of this feature apart form 802.1A...
DaneA
Jul 22, 2021NETGEAR Employee Retired
As far as I have checked, the M4250 Series Switch Models supports gPTP. Be informed that you need to purchase an AVB license (sold separately) to use gPTP.
Kindly check the M4250 series Data Sheet on this link. Check pages 12, 44 and 45 wherein gPTP is mentioned.
DaneA
NETGEAR Community Team
Elad6L
Aug 12, 2021Aspirant
Thank you DaneA.
What about M4300? can gPTP be supported there (even with additional license)?
Elad
