pertronic
Apr 03, 2012Aspirant
Access management VLAN from other VLANs
We will soon replace our switches with managed switches from Netgear (a couple of GS724T and one GSM7224). I've been successfully testing a multiple VLAN config with the GSM7224 handling the inter...
Nariman
Aug 01, 2012Aspirant
Why don't you create another VLAN, call it 'Management VLAN' and then put all the switches and ... to be managaed,part of this VLAN.
This way, then you can completely remove VLAN1 and use the other VLAN as management.
