dardwizzle
Jun 18, 2018Guide
Accessing GS108Tv2 via Mobile App
Hi Guys,
I have my switch connected to my LAN but I am unable to get the Android App "Netgear Insight" to connect and see the switch. The switch is listed within the app, but when I try to access ...
Carl_z
Jun 18, 2018NETGEAR Expert
Hi dardwizzle ,
Welcome to the community!
If you want to dicover and manage GS108Tv2, you should put your Android app in same subnet with the GS108Tv2. So does your Android in same LAN as GS108Tv2?
BestRegards
Carl
Netgear Employee
schumaku
Jun 19, 2018Guru - Experienced User
Discovery works regardless of the subnet, all what's required for the NETGEAR Switch Discovery Protocol (NSDP) for discovering the device by the NETGEAR Plus Utility and NETGEAR Insight is a transparent Layer 2 network (LAN, WLAN).
The GS108Tv2 - like many other non-Insight enabled network devices - has only "limited support" by the Insight App.
While the NETGEAR Plus Utility is able to communicate and configure the switches using Netgear NSDP, too - the NETGEAR Insight App can only discover and assist with the device registration for the "limited support" (non-Insight enabled) devices. To manage these, a Web browser connection is required - thus either the same IPv4 subnetwork is required, or a properly routing environment must be in place.
