netsmart
Oct 26, 2016Aspirant
Accessing sites thru local network VPN hardware
We have a Prosafe FVS336G Firewall/VPN. We'd like to set this so that users within the LAN can access sites on the internet as if it were an external VPN. A loop back tunnel of sorts to other sit...
JohnRo
Oct 28, 2016NETGEAR Employee Retired
Hello netsmart,
Welcome to the community!
You can do a box-to-box VPN configuration if you will have two FVS336G's on both ends. However, your fios box, does it have routing capabilities?
Thanks,
netsmart
Oct 28, 2016Aspirant
Yes, the Fios Gateway is a router ( Fios G1100). it does routing. The FVS336G is connected to one of it's Lan ports.
The task here is to use the FVS336G as a VPN service such that INCOMING data is encrypted ( trading data for example ) and geolocation is not available to sites ( via IP lookup -- verizon ).
So instead of subscribing to a VPN service we provide our own, in a nutshell.
Thanks.
- JohnRoOct 31, 2016NETGEAR Employee Retired
Hi netsmart,
Well, then there are two routers connected to each other. For you to use the VPN capabilities of the FVS336G you'll have to setup a DMZ port on the FiOS to the IP of the FVS336G. What you're looking for is possible but DMZ should be configured on your FiOS.
Thanks,
- JohnRoNov 03, 2016NETGEAR Employee Retired
Hi netsmart,
Do you have an update regarding this? Do you still have any issues?
Thanks,
- FramerVNov 06, 2016NETGEAR Employee Retired
Hi netsmart,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Regards,- netsmartNov 06, 2016Aspirant
Still working our way thru this. The DMZ should be set up on the prosafe, as there's TWO incoming Wans for loadbalancing, failover, etc.
Need to do the DMZ, . While I have the latest firmware, the model is not the latest ( ie. no DMZ LED)
Thank you.
- JohnRoNov 07, 2016NETGEAR Employee Retired
Hi netsmart,
No need to DMZ on the FVS336G since it is the one behind the modem/router. You'll need to setup the DMZ on the FiOS to let the FVS336G pass the VPN.
Thanks,
