miamiheat's avatar
miamiheat
Follower
Jan 17, 2013
Adding DHCP Option 156 to a GSM7228PS?
Can anyone guide me to how to add DHCP Option 156 to a GSM7228PS? In the Web interface I see DHCP Pool Options, but when I choose Option Code 156 and Option Type ASCII, I am limited to 15 characters, which is not sufficient to enter the value that is required of our VOIP Phones of ftpservers=192.168.xx.x, country=n, language=n, laver2tagging=n, vlanid=n
Any ideas:confused:
Thanks!
1 Reply
  • Did you get this resolved?
    The web gui wont allow you to enter past 15 characters
    you need to use the cli
    enable
    config
    ip dhcp pool Name - The pool name is case sensitive. You can view pool names in Web Gui
    option 156 ascii ftpservers=1.1.1.1,country=1,language=1,layer2tagging=1,vlanid=1
    Enter it for the Data and Voice Vlans
ProSupport for Business
