moonwatcher64
Mar 02, 2025Luminary
Advice on Suitable replacement of Netgear Prosafe GS748TPS Switches
Evening folks. I have two GS748TPS's in a home environment that have done super work the last 12+ years. But they got water damaged recently and are approved for replacement by the insurance company....
schumaku
Mar 07, 2025Guru - Experienced User
moonwatcher64 wrote:
I had in mind to replace with GS752TPPv3's. ... But then looking at the Netgear support web site, it says these units are end of life/discontinued?
https://www.netgear.com/support/product/gs752tppv3/
Double check you are really looking at the curent v3 version.
