chrish1984
Sep 23, 2015Aspirant
Advice required on what I need to buy
Hi all I've been tasked with distributing broadband across a campus and have a few questions regarding switching... Another department has installed a 1000mb BT broadband bearer within a WAN ...
- Oct 02, 2015
Hi chrish1984,
I understand the distances now (I got confused before). I did find a solution but we still need to get back to our original problem, qouted below:
chrish1984 wrote:
If I procure a 1gb distribution switch, how will this connect to the 10gb port on the core switch?
I found the model M4100-12GF, this will be the switch under the core switch (if we can use a 1G port from the core switch). For the 4 other switch, I am suggesting models M4100-26G or M4100-50G. If there is no choice but to use the 10G, I'll see if I can find another solution and get back to you on that.
Thanks,
chrish1984
Sep 24, 2015Aspirant
Hi JohnRo
Thanks for your input.
I would be grateful if you could recomend some products.
Many thanks
Chris
JohnRo
Sep 25, 2015NETGEAR Employee Retired
Hello chrish1984,
I would like to introduce you to our high speed 10-Gigabit switches family. You may have to decide first on how many ports you are going to utilize, do you already have swicthes on the locations? I am quite concerned about the OM1 cables might not deliver 10Gb (just like what I have mentioned on my first post you'll need to use the correct cables and modules to reach 10Gb speed on the distance you mentioned, see this article).
If you have more questions, feel free to ask.
Thanks,
- chrish1984Sep 26, 2015Aspirant
Hi JohnRo
My bacbone lengths are too long for 10gb over OM1, Eventhough I won't aceive 10gb will the distribution switch still link to the core switch over greater distances.
Otherwise I'll have to go for a 1gb coe switch. what do you think?
Cheers
Chris
- JohnRoSep 29, 2015NETGEAR Employee Retired
Hello chrish1984,
Given the length and cabling limitations, I believe 1Gb is the fastest we can go. You can choose from our wide range of smart gigabit swicthes (configurable models), it'll be able to help you manage and monitor network traffic.
Hope it helps
Thanks,
- chrish1984Sep 29, 2015Aspirant
Thanks JohnRo you have been a massive help.
1 more question...!
The core switch I'm getting the broadband from only has a 10gb port configured for my use. If I procure a 1gb distribution switch, how will this connect to the 10gb port on the core switch?
Thanks
Chris H
