chrish1984's avatar
chrish1984
Advice required on what I need to buy
Hi all   I've been tasked with distributing broadband across a campus and have a few questions regarding switching...   Another department has installed a 1000mb BT broadband bearer within a WAN ...
  • JohnRo's avatar
    JohnRo
    Oct 01, 2015
    Hi chrish1984,
    I understand the distances now (I got confused before). I did find a solution but we still need to get back to our original problem, qouted below:
    chrish1984 wrote:
    If I procure a 1gb distribution switch, how will this connect to the 10gb port on the core switch?
    I found the model M4100-12GF, this will be the switch under the core switch (if we can use a 1G port from the core switch). For the 4 other switch, I am suggesting models M4100-26G or M4100-50G. If there is no choice but to use the 10G, I'll see if I can find another solution and get back to you on that.
    Thanks,
ProSupport for Business
