chrish1984
Sep 23, 2015Aspirant
Advice required on what I need to buy
Hi all I've been tasked with distributing broadband across a campus and have a few questions regarding switching... Another department has installed a 1000mb BT broadband bearer within a WAN ...
- Oct 02, 2015
Hi chrish1984,
I understand the distances now (I got confused before). I did find a solution but we still need to get back to our original problem, qouted below:
chrish1984 wrote:
If I procure a 1gb distribution switch, how will this connect to the 10gb port on the core switch?
I found the model M4100-12GF, this will be the switch under the core switch (if we can use a 1G port from the core switch). For the 4 other switch, I am suggesting models M4100-26G or M4100-50G. If there is no choice but to use the 10G, I'll see if I can find another solution and get back to you on that.
Thanks,
JohnRo
Oct 02, 2015NETGEAR Employee Retired
Hi chrish1984,
Thanks,
chrish1984
Oct 02, 2015Aspirant
Thanks JohnRo this is really helpful.
If you could possibly find a 10gb solution I would be grateful. In the meantime I'm going to investigate the feasibility to using a 1gb port on their switch.
Thanks
Chris
