robfantini's avatar
robfantini
Boot Version NULL
Hello
I just upgraded the firmware on this switch.  after that the ' boot version'   is blank:
(GSM7352Sv2) #show running-config
!Current Configuration:
!System Description "GSM7352Sv2 48-Port Gigabit Layer 3 Stackable Managed Switch with 2 10G SFP+ port, 10.0.0.53, <not found>"
!System Software Version "10.0.0.53"
Is this something that should be fixed -  missing ' Boot Version' ?
Roberto
  • OK SO I took a chance and added the switch with no boot version to the stack.
    that fixed the  no boot version.   now it has same version as the other 2 switches.
  • I have 2 other of the same model switch.  Maybe a backup and restore can fix this issue?
     Maintenance > File Upload >  File type :  Archive    include boot code?
    • robfantini's avatar
      robfantini
