Peacheater
Jul 30, 2020Tutor
can a Managed switch be used as Unmanaged?
This might be a dumb question, but here goes. Can a Managed switch be used as Unmanaged? At the moment I only need an unmanaged switch, but MIGHT find a need or use for a managed switch in...
- Jul 30, 2020Yes, you can! Default settings should be fine for you, in principle, and management will be available in the future for you.
LaurentMa
Jul 30, 2020NETGEAR Expert
- PeacheaterJul 30, 2020Tutor
Thanks for a quick and clear reply. VERY helpful.
cheers!
