Peacheater
Jul 30, 2020Tutor
can a Managed switch be used as Unmanaged?
This might be a dumb question, but here goes. Can a Managed switch be used as Unmanaged? At the moment I only need an unmanaged switch, but MIGHT find a need or use for a managed switch in...
- Jul 30, 2020Yes, you can! Default settings should be fine for you, in principle, and management will be available in the future for you.
LaurentMa
Jul 30, 2020NETGEAR Expert
Peacheater
Jul 30, 2020Tutor
Thanks for a quick and clear reply. VERY helpful.
cheers!
