JonCJohnson
Jul 26, 2017Follower
Can I disable EEE on the GS418TPP?
Hello- I need to verify that EEE can be disabled on this switch. Any assistance would be greatly apprecaited! Thanks
LaurentMa
Jul 26, 2017NETGEAR Expert
Hi JonCJohnson
Yes, you can deactivate EEE on this GS418TPP in particular, and on all switches supporting EEE at NETGEAR, in general.
For GS418TPP, you can follow the User Manual indications on page 67: Select System > Management > Green Ethernet > Green Ethernet Configuration.
Support page: https://www.netgear.com/support/product/GS418TPP.aspx
