DavidA2014
Jul 04, 2014Aspirant
Cannot discover GS108T
Hi My GS108Tv2 switch was working ok. Then I performed a factory reset (because of various problems). I set my local PC address to 192.168.0.1 and I have only that PC connected to the switch. I ha...
RX
Dec 03, 2014Luminary
Another solution is to disable the software firewall/anti-virus installed on your PC such as Norton, Eset, Vipre, etc. or create a rule to allow to run the Smart Control Center on the software firewall/anti-virus.
