rkadsit
Oct 11, 2017Aspirant
Cannot download bootcode to GS724TP
I have downloaded upgrade files which included the bootcode for my GS724TP. It needs version 1.0.0.5 before I can upgrade further. Every time I try to download the file to the switch from my PC, it...
JohnC_V
Oct 13, 2017NETGEAR Employee Retired
Hi rkadsit,
Here's what I found on the release notes that you can try.
To update boot code:
- If the switch has firmware version 1.x, log into the switch’s GUI, go to Firmware > File Management > File Download. Follow the instructions to download boot code version version 1.0.0.5 to the switch.
- If your switch has firmware version 2.x, log into the switch’s GUI, go to Maintenance > Download. Follow the instructions to download boot code version version 1.0.0.5 to the switch.
After download completed, reboot the switch. When the switch booted up, verify from the GUI the switch’s boot version has been upgraded to v1.0.0.5 before proceeding any further.
- If the switch has firmware version 1.x, the switch must be upgraded to the interim image (GS700TP_V1.0.0.inter.ros) first. Then, perform the upgrade again from the interim image to V3.0.6.1.
- The procedure for upgrading the device to the interim image is the same as the regular firmware upgrade. It can be downloaded to the switch by using the GUI via a TFTP server or by using Smart Wizard Discovery utility.
Here is the link for reference. If ever that it is still not working, try to reset it to factory default and see how it goes from there.
Regards.
- rkadsitOct 13, 2017Aspirant
Thanks for responding JohnCarloV, but I already tried that very same procedure. The problem is I get an error that the copy to the switch failed. I used the HTTP transfer method from my PC.
Bob
- JohnC_VOct 16, 2017NETGEAR Employee Retired
Please do try using TFTP download. Here is the TFTP server that we use.
You may also follow this article.
- rkadsitOct 17, 2017Aspirant
Thank you very much JohnCarloV! That did the trick. I wonder why the HTTP transfer did not want to work. Was that always a problem?
