rkadsit
Oct 11, 2017Aspirant
Cannot download bootcode to GS724TP
I have downloaded upgrade files which included the bootcode for my GS724TP. It needs version 1.0.0.5 before I can upgrade further. Every time I try to download the file to the switch from my PC, it...
rkadsit
Oct 13, 2017Aspirant
Thanks for responding JohnCarloV, but I already tried that very same procedure. The problem is I get an error that the copy to the switch failed. I used the HTTP transfer method from my PC.
Bob
JohnC_V
Oct 16, 2017NETGEAR Employee Retired
Please do try using TFTP download. Here is the TFTP server that we use.
You may also follow this article.
- rkadsitOct 17, 2017Aspirant
Thank you very much JohnCarloV! That did the trick. I wonder why the HTTP transfer did not want to work. Was that always a problem?
