rixIT2
Apr 13, 2025Aspirant
Cant get Managment VLAN to stick on a MS510TXUP
I cant get Managment VLAN to stick on a MS510TXUP. I try to change the Managment VLAN from default 1 to 9 on System / Managment / IP Configuration. I get the warning screen. Hit okay... and nothin...
schumaku
Apr 13, 2025Guru - Experienced User
Looks like a newly introduced issue, was fine during the Beta phase. Something to carry forward to Netgear support please and BretD.
-Kurt.
PS. As the MS510TXUP is not a fully Managed Switch, I'll suggest a moderator to move this thread to the more appropriate Plus and Smart Switches Forum to discuss Smart Switches (T) and Plus Switches (E), including Local and Remote Management models.
rixIT2
I have tried to update to 1.0.5.23 and still have the same issue.
Yea I cant find anything about it..
A my 4 units gives the same problem... changing the Mgnt VLAN ID does not stick.
- rixIT2Apr 13, 2025Aspirant
Same problem on firmware v1.1.0.7
Change the Mgmt VLAN ID in the new interface. Still sticky to VLAN ID 1... does not change.
I've tried this and get the same error on the following versions
v1.0.5.17 (3 still of this version.)
v1.0.5.23
v1.1.0.7 (present on one of them) - schumakuApr 13, 2025Guru - Experienced User
Could be a management Web UI issue, too.
Alternatively, give the Netgear Lite CLI a try, p.60 ff.
The hardcore version would be to download the config from the switches, carefully edit the management VLAN, and upload the modded file again. But please taker a backup from the config first, and store at a safe place.
[EDIT] Can't locate the management vlan config section in the text config export from my MS510TXUP, sorry. [/EDIT]
Thanks for the support and the idea of using CLI.
Tried and failed with same.. does not stick 🙂 No error message.Sw6# configure Sw6(config)# management-vlan vlan 9 Error! Management access will be lost on MGMT VLAN configuration. Sw6(config)#- rixIT2Apr 13, 2025Aspirant
One thing I have noticed is that there is under Address Table a C1 Managment Interface. I cant access that under Switch / VLAN menu...
