rixIT2
Apr 13, 2025Aspirant
Cant get Managment VLAN to stick on a MS510TXUP
I cant get Managment VLAN to stick on a MS510TXUP. I try to change the Managment VLAN from default 1 to 9 on System / Managment / IP Configuration. I get the warning screen. Hit okay... and nothin...
rixIT2
I have tried to update to 1.0.5.23 and still have the same issue.
Yea I cant find anything about it..
A my 4 units gives the same problem... changing the Mgnt VLAN ID does not stick.
rixIT2
Same problem on firmware v1.1.0.7
Change the Mgmt VLAN ID in the new interface. Still sticky to VLAN ID 1... does not change.
I've tried this and get the same error on the following versions
v1.0.5.17 (3 still of this version.)
v1.0.5.23
v1.1.0.7 (present on one of them)
