rixIT2
Apr 13, 2025Aspirant
Cant get Managment VLAN to stick on a MS510TXUP
I cant get Managment VLAN to stick on a MS510TXUP. I try to change the Managment VLAN from default 1 to 9 on System / Managment / IP Configuration. I get the warning screen. Hit okay... and nothin...
rixIT2
After extensive research together with the support. This is a bug. Please avoid this product until they fix this issue. You cant change the Managment VLAN ID in a normal way. This is very problemantic. Not even Ciscos switches works this bad... hope they fix this soon.
