Comprido
Apr 01, 2021Aspirant
can't make the sfp work on the m4100-26g-poe
Hello, I hope somebody can help me. I am having troubles connecting a 10GB Copper SFP to a M4100-26G-POE I have connected the SFP to port 26 (the last port on the bottom right) and I have not p...
- Apr 01, 2021
Unfortunately no. By rule of thumb, SFP+ slots can take SFP modules (for Gb fiber links for example to connect an SFP and an d SFP+ device), but SFP slots can't take SFP+ modules.
As I said, SFP resp. SFP+ does not have a link speed negotiation, it's an (out of band when I have it right) control protocol between the module and the host. SFP can do Gigabit, host permitting also 100 Mb/s in an SFP slot, SFP+ can to 10G and 1G (host permitting again) in an SFP+ slot.
Before you are running crazy, be aware there are SFP+ RJ45 copper modules supporting MultiGig on the copper link - this does on the vast majority of SFP+ devices (switches) not work, as most support 10G and 1G only but _not_ MultiGig on the SFP+ slots.
schumaku
Apr 01, 2021Guru - Experienced User
At no point, the M4100-26G-PoE does support anything beyond of Gigabit. All M4100 ports, including the SFP slots, are Gigabit Ethernet only (one model verion has Fast Ethernet ports) - the SFP slots offer "100Mbps backward compatiblity on all SFP ports". -> M4100 Series Data Sheet
SFP+ modules are not workable on SFP modules.
Don't get confused about the fact that the SFP+ RJ45 modules are when powered on SFP ports auto-negotiate the link between the two modules. On the SFP/SFP+ host side, there is no such autonegotiaion, just like on fiber.
Comprido
Damn, I don;t believe how noob I am...
For some strange reason, I was with the impression that the SFP ports support 10gb
Thanks for the reply :)
Just another question, should those SFP ports not work at least at 1GB? (obviously not at 10gb since it's not supported, but should they not work at least at 1gb?)
- schumakuApr 01, 2021Guru - Experienced User
