Quantumn
Apr 29, 2018Aspirant
Cascading Switches
How is it, that I can connect a managed switch (GS105PE) into another managed switch (GS728-PE), and not be able to reach the first one? But only when I plug another device into the first switch.
JohnC_V
May 01, 2018NETGEAR Employee Retired
Hi Quantumn,
You mean that there are multiple devices connected to the GS105PE, but, when you connect a device to port 3, the data is not passing through anymore. Is that correct? Does the switch turns off if there is a device connected to port 3?
