Ghila96
Nov 03, 2016Aspirant
Cascade Router
Hello everybody,
I cascade Netgear DGND3700v2 to a modem of my provider (LAN to LAN). I followed this steps:
1) Adapt DHCP range (for main modem in set from 192.168.0.2 to 192.168.0.254 and its IP is 192.168.0.2, while for second modem, the DGND3700v2, is the IP is 192.168.0.1)
2) Disable DHPC, firewall and NAT to second modem (this featureas are active on first modem).
3) Change DNS, which match to first router IP
All work properly, I'm able to surfing web. However, I 've a some problem:
1) Router time isn't correct: from advanced > Security > Schedule I'm not able to set time manually.
2) I' ve problem with "turn off wireless signal by schedule" functions, it's inactive.
I attach two image.
Thanks for all replies.
- Retired_MemberNov 06, 2016
You're Welcome,
search the web for your ISP modem and or call ISP and ask them to place it in bridge mode OR purchase a Access Point.
- Retired_Member
Time info is routed thru the WAN port if WAN isn't used it will not update
- Ghila96Aspirant
Thank you for reply,
There is no way to set manually time?
And for the other problem what is the solution?
Thank you!
- Retired_Member
You're welcome,
You're using the router in a way it was not intended to be used, So it has limitations, when WAN port is not connected time won't sync, and turn off WIFI via schedule won't work either.
